data reading rate
I am trying to control the rate at which a file is read. (ex. one value per second) How do you set the program to read one value from a text file per time value? Also, if the time values were included in the text file, how would you correlate the time value to the other graphical value?
Thank you!
Ellie
(3,073 Views)
I would set a loop with a Read Characters function set to read one value or character or whatever. Also in the loop, put a Wait Until Next ms Multiple set for 1000. This will run the loop once per second.
If you read your value and then read the next time interval, you can use that interval to set the timer for your next read. I hope that's not too confusing.
Rob
(3,073 Views)
I don't understand where in the loop to put the Wait Until Next ms Multiple. What do I connect the output to?
Thank you.
(3,073 Views)
If i'm not wrong, you must put the wait inside the loop, and don't have to connect the output anywhere, this way, the loop will wait untill the time you put in it to execute again.
Hope this helps
(3,073 Views)
