data record with pause in the middle
hello
i'm using labview 8.6
i'm trying to make a code that will allow me to record an analog output channel (of DAQ 6259).
my problem is that i need to record the channel alternately (for example record for 30msec stop for 200msec record for 10msec stop for 50msec and so on), and i cant have any delays between my record/stop command and the execution of the command (at least not from the recorded data point of view).
i tried to enter the data to an array inside a while loop and my while loop is inside a case that choose if it's record time or pause time.
the problem is that if i do that the loop control is not that efficient and the data is not sequential.
does anyone have any idea how can i do this correct?
(3,733 Views)
What determines when the start and stop commands occur?  How does the software get this information?  The times you suggest are much too fast for a human user to generate.  Are they predefined or on an analog or digital input channel?
In any case I suggest that you set up to acquire the data continuously and then extract the sections you want to record.  A Producer/Consumer architecture might be appropriate.
Lynn
(3,725 Views)
You could also have a 2-sequence inside a loop, with the time (in ms) determined by you entering numbers into 2 different controls.  You could also control how many iterations using external controls, which will affect how long the entire data gathering section is viewed.
Please be a little more clear on what you actually want to do.
(3,710 Views)
I would recommend implementing your data collection inside a state machine. This would give you the flexibility to control your data collection in any way you want and allow you to extend your control in the future. I would avoid using sequence frames to control your operations.
Message Edited by Mark Yedinak on 10-13-2009 01:19 PM
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,705 Views)
Along John's line - could you give more information, because without the details it is hard for anyone to provide a good recommendation.  If you data acquisition is triggered off a user event, I would be hard pressed to believe that you will ever get the kind of performance that you are looking for.  But, if the  acquisition is based off of a timing diagram, I think that there might be ways to efficiently collect the data at the intervals you are seeking.
Matt
(3,691 Views)
i'll try to be more specific:
i have an algorithm in matlab i suppose to run in labview (with math script).
the output of the matlab is int 16 [] is suppose to transmit  by analog output of my DAQ.
i also need to record this output.
the system that read the output works in millisecondes resolution.
between one iteration of the algorithem on another iteration i have a 200msec setup time that i dont want in my record.
after i run this test i want to be able to run my record to the system without the setup time, that means i need the data to be sequential and not to have even 1msec delay between one iteration and the other.
thank you for your help
(3,672 Views)
Can you post the code you have thus far?  Or possibly provide the signal you are wishing to output for D/A?  Thanks, Matt
(3,665 Views)
