data saving in host
I have some experience with LabView but none with this hardware.i am new using CRIO system(9004).how i can save the data using crio any example for this .
Message 1 of 13
(5,683 Views)
There's a CompactRIO Developer's Guide here.
Message 2 of 13
(5,666 Views)
any example for data saving in host
Message 3 of 13
(5,658 Views)
LabVIEW also comes with ready-to-use example projects explaining data communication between host PC and cRIO target!
Message 4 of 13
(5,655 Views)
See Section 6 for an overview and description of the Sample codes.
Message 5 of 13
(5,653 Views)
You need to use two applications: one on your cRIO and one on your host/PC.  You can send data between the applications using TCP/IP functions (look up the STM library) or Network Streams.  So using this communication, you send messages to the host telling it to save the data being sent.
Message 6 of 13
(5,622 Views)
i am using this example to read data from CRIO-9004.how i can datalog from this example. i need to save data for 100hz(sampling data)in the format of tdms or lvm. otherwise guide me for any example to datalog.
Message 7 of 13
(5,611 Views)
Hi maintenanace,
do you really want a "datalog" file or just a logfile of your data (which can be something completely different)?
LabVIEW comes with a huge library of example VIs, there are sure examples explaining how to use file functions…
Message 8 of 13
(5,600 Views)
hi there,
as crossrulez said, you have to have a mechanism of transferring data to your PC,
you have several options:
1. build your own TCP/UDP
2. Network Streams
3. Network Shared Variables
https://www.ni.com/docs/en-US/bundle/labview/page/data-communication-methods-in-labview.html
afterwards you can write the data to TDMS
  * https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PcCAI&l=en-US
  * https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
or .csv-/text-file
have a look in the examples coming with labview (search for TDMS or Network Streams)
with SSP you have online training which has two courses on RT
LabVIEW Real-Time 1
The LabVIEW Real-Time 1 course delivers hands-on training for prototyping deterministic measurement and control systems. At the end of the course, you will be able to design, develop, and prototype a real-time application that handles communication between the RT target and a host computer using NI recommended methods and LabVIEW Real-Time.
LabVIEW Real-Time 2
The LabVIEW Real-Time 2: Architecting Embedded Systems course delivers hands-on training for designing scalable, maintainable, and reliable embedded applications. At the end of the course, you will be able to translate your embedded system requirements into a scalable software architecture, choose appropriate methods for inter-process and network-based communication, design your real-time application for reliability, and efficiently deploy and replicate your real-time systems.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 9 of 13
(5,599 Views)
Hi GerdW
Thank you for your reply.
i need real data log from the crio
Message 10 of 13
(5,577 Views)
