data socket connection with OPC server error in runtime
I have developed application with data socket connection(publish) in Labview 7.1 version @ client PC.
In server PC I have OPC server installed. I am able to make connection(subscribe) and view the values.
When I make the application inserver as executable, i am not able to view the values. Means values whatever is chnging in client is not getting update at server.
What may be the problem?
(2,903 Views)
Hi Prakash,
If you are programmatically opening and closing the DataSocket server, you will need to include DataSocket Server Control.vi as a Dynamic VI when creating the executable.  More information is in the KnowledgeBase article Why Won't My LabVIEW DataSocket Program Run As An Executable?
Jennifer R.
(2,883 Views)
