data to excel limited to 3 digits of precision
I can't write a floating point number smaller than 0.001 to excel. If I try to write 0.0037, 0.004 is written to excel. Writing 0.0003 results in 0.0000 being written to excel. If I write a very small number directly in excel, I can correctly read it from LV. I am using LV Report Generation Toolkit for MS Office V1.1. I expect this is a configuration problem in either LV or excel but can't find it. Any suggestions?
Example code is attached.
(2,927 Views)
Hi Bob,
If you look into the "Write to spreadsheet file", there's an input for the format specifier. This defaults to %.3f, which will save binary data in ASCII with only 3 decimal places. If you need more (say 10) then wire a string with %.10f and it should work fine.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,914 Views)
Shane,
Thanks for the pointer. I figured this would be something easy. I didn't think to open Excel Easy Table.vi and snoop around.
Bob
(2,904 Views)
