data to text file with header
for my test application i want to store the test data into a text file with header. This should be like this:
name, serial, count, min. current, max. current
Mister Smith
1234567890
111
10
1000
data:
1 345 34
2 355 23
3 360 34
The first row are only informations about the headers rows. "data:" is the start marker of the data. The data consists  of a number, the mean value of current an the test time in s.
Now i write an string array to the text file, but if the length of the header change i overwrite the data. For example the name is Mister John Smith.
In my program i can create a new file with header and i can change the header later. In the measurement routine i put the data into the file.
How can I solve this?
thankyou
schwede
(3,750 Views)
Hi Schwede,
the easiest would be to disallow changing the header after start of the measurement. (That's reasonable, don't you think so?)
The next best option is to use a fixed-sized header - easiest when you need to change the header later on.
A 3rd option is to reload the whole file, change the header and write the whole file again - there is no "insertion" possible for files...
(3,742 Views)
"The next best option is to use a fixed-sized header - easiest when you need to change the header later on."
How can I do this?
(3,737 Views)
Hi Schwede,
by writing a fixed-sized string? (fill up with spaces, empty lines, tabs, #, whatever you like Smiley Wink )
(3,733 Views)
I think the constant Header size is good, but i can`t made it.
Have you an example for me please?
(3,718 Views)
Accepted by topic author Schwede
Hallo Schwede,
here's an example:
Be carefule and make some checks, at the moment it will cut "your input" when it exceeds 512 bytes...
(3,711 Views)
