data transfer problem
hi,
i have a problem for data transfer from sub vi to main vi. i post my vis, please hlep me to check the things.
thanks
(2,988 Views)
To get an answer you should first explain with some details:
1) what you are trying to do
2) what goes wrong with your current vi's
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,976 Views)
I guess you are planning to transfer some data from this “control panel vi” to “main menu vi”, I think you can just use the traditional method instead of using invoke node. Place the “control panel vi” inside the “main menu vi” as a sub-vi. You can connect the whole data storage cluster to one single connector.
When you feel sad, laugh
(2,972 Views)
