data type errors
I am getting this error when I connect  History Data Property Node to mean:
" These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is 1D array of double [64-bit real (~15 digit precision)]. The type of the sink is double [64-bit real (~15 digit precision)]. "
Please help me to resolve this error. Any help will appreciate. Thanks in advance.
Message 1 of 16
(5,914 Views)
Are you using the PtByPt Mean? The standard Mean function has an array for an input.
Message 2 of 16
(5,911 Views)
I am using pt by pt mean
Message 3 of 16
(5,906 Views)
That explains the error then. Why did you pick that function?
Message 4 of 16
(5,904 Views)
Coz I have taken the values from graph and it takes the mean of all point in graph.
Is any way to resolve this error????
For your informatiom, I want to take the mean or average of output points that is displaying in graph. Is any way to take the avergae of all output values of graph?????
Message 5 of 16
(5,886 Views)
Yeah use the Mean.VI instead of Mean ptByPt.vi.  Read the help on these two functions and you'll see one takes an average of a bunch of points, while the other takes one new point at a time to be averaged.
Message 6 of 16
(5,884 Views)
How to find Mean.VI and used in my program??????
Message 7 of 16
(5,880 Views)
I told you to use the Mean function in my first answer.
Use the search button on your function palette or use quick drop.
Message 8 of 16
(5,877 Views)
Thanks dear.
Can you tell me that where to connect the output of Mean.vi to see the mean result??????
Message 9 of 16
(5,875 Views)
Thanks dear.
Message 10 of 16
(5,871 Views)
