database and labview 8.5
I am looking to do some database code for an application in labview 8.5 and windows XP (maybe vista as well).  I havent done much database with labview in a few years and am looking for any pitfalls to avoide.  I need do choose the right DBMS access, mySql ..... and also know if there are know issues og the database toolkit.  Has anyone had any problems or suscess using 8.5 and databasing.  I will be writing moderate amounts of data to the data base, I will be updating fields several times per minute and the system will run mostly continous 24/7
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,841 Views)
Does anyone use databases with 8.5?
Paul Falkenstein
(2,811 Views)
Hi Paul,
You should be able to use the Database Connectivity Toolkit with LabVIEW 8.5 just fine.  There is a list of supported databases here so you should be able to select the database you want.
Donovan
(2,795 Views)
