database bigint
There is a column in my database table with the datatype called "bigint", which is just an int with a bigger range.  When I use the database toolkit to tool the bigint data, instead of getting a bigint value, I get a blank.  How do I fix that?
Yik
Kudos and Accepted as Solution are welcome!
(4,411 Views)
Someone help!  Why can't I query bigint datatype fromn database?
(4,393 Views)
Kind of hard to help without getting more information, perhaps even a copy of the code where you are trying to read this "bigint".
What exactly is a "bigint"?  What is the bigger range of values it could possibly have?
(4,387 Views)
Accepted by topic author jyang72211
What functions in the toolkit are you using? I have hardly used the toolkit at all (I use LabSQL) but I think the Database Variant to data should work if you specify I64 as the data.
(4,385 Views)
Cool, that worked.
(4,366 Views)
