database connectivity question?
when I select the OLE DB provider is "microsoft OLE DB provider for
ODBC Drivers",I can write to database,but I can't read from database
using data connectivity toolkit?
but when I select the OLE DB provider is "microsoft JET 4.0 OLE DB
provider"
that's no problem.i don't known why?
thank you in advance!
yhg-163@163.com
(3,398 Views)
Please look at the LabVIEW Database Connectivity User Manual, specifically chaper 2, as it explains in great detail the differences between the two different providers. Good luck!
(3,398 Views)
ebarker wrote in message news:<506500000005000000DD060100-1042324653000@exchange.ni.com>...
> Please look at the
> href="http://www.ni.com/pdf/manuals/321525c.pdf">LabVIEW Database
> Good luck!
I have saw LabVIEW Database Connectivity User Manual,I can't get some
useful information.
using data connectivity toolkit?I stored data in access database (.db
file) and i use the SQL language:
SELECT * FROM motor WHERE serial="aaa"
the error is :
"error-21472179
04 occurred at conn Execute.vi-fetch record.vi(myvi).
possible reasons:
Invlid string:specified field does not exist or contains an
unsupported character"
provider" ,i can read the record using the same language.
(3,398 Views)
