database connectivity timeout
   I'm using the database connectivity toolkit to connect to a MySQL database. If the database isn't there or there is a mistake in an SQL query after I have connected my program takes 15s (the default) to realise. I've tried wiring different values to the connection timeout node but this doesn't seem to make any difference whatsoever. I've hacked the first problem by pinging the machine with the DB on before trying to connect as suggested in another post, but this doesn't help if I screw up my INSERT syntax... any ideas what could be wrong?
       Cheers,
              Tim
(6,512 Views)
Hi Tim,
You should be able to use the command timeout (s) parameter of the DB Tools Set Properties VI of the Database Connectivity Toolkit to set the maximum time to wait for a command to execute, in seconds.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(6,477 Views)
Thanks Imtiaz, that's sorted my problems - I don't suppose you have any idea why the timeout value I'm wiring to the Open Connection VI isn't working? I can't set the connection properties as you suggest until after the connection is open so I'm still having to check for the presence of the DB machine before opening.
   Cheers,
           Tim
(6,441 Views)
That timeout value is explicitedly for the Open operation itself. The server could be slow to answer, or behind many low speed network connections or as in your first problem not even listening at the address you provided, so there is a use for that.
Message Edited by rolfk on 11-22-2009 01:44 PM
Rolf Kalbermatter  My Blog
(6,419 Views)
I had the same problem with the database connection timeout not working, so I created this VI to check for connectivity before opening a connection.
Message Edited by LabBEAN on 02-19-2010 06:17 PM
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(6,240 Views)
Hi!
Sorry for resurrecting this 15 years old topic, but it's #1 when searching for this topic.
Hmm, this VI is identical to the open VI from the toolkit, except it closes the connection directly after establishing it:
It's the _Connection.Open() method that ignores the timeout set before, and returns after about 40s in my case.
Just my thoughts about it:
Those are high level functions, the actual communication with the database is done by a driver underneath. One driver may handle the timeout correctly, the other may not. In my case, it's MS SQL, and it ignores the timeout.
For MS SQL, I wrote the snippet below, which runs no longer than the specified timeout. It mimics the initial connection to the database on network level, which is:
  1. Send a UDP packet to port 1434 of the DB server, containing just \0x04InstanceName
  2. Wait for UDP packet from the DB server, [... which contains \0x05, the instance name and the actual port where that instance is listening.
  3. Open the actual TCP on that port for database communication ...]
The snippet uses the first free port between 20000 and 20500, and does not evaluate the returned packet, but it works for my needs.
(1,655 Views)
