database connectivity without toolkit
Is it possible to connect to an SQL database without the database connectivity toolkit?  I've learned that I can create Excel reports without the report generation toolkit so I thought it might be possible?
Ron Deavers, CLD
Message 1 of 11
(8,157 Views)
Accepted by topic author programmindragon
"programmindragon" <x@no.email> wrote in message
news:1222726210026-784473@exchange.ni.com...
connectivity toolkit?&nbsp; I've learned that I can create Excel reports
Sure, you could also use a free SQL toolkit: LabSQL. Both the DCT and LabSQL
are based on ADO ActiveX component, so you can also make something yourself.
Wiebe.
Message 2 of 11
(8,140 Views)
I've used LabSQL and am pleased.  It doesn't have the bells & whistles of the toolkit, but it works well (if you're familiar with SQL).  You can see that LabSQL doesn't use a UDL file, but relies on a DSN.  That's not as convienient, I think.
code capture
jm
PS - I didn't come up with that clever table name Smiley Surprised
Jim
Message 3 of 11
(8,137 Views)
Thank you both for your help.  I will give it a try.
Ron Deavers, CLD
Message 4 of 11
(8,102 Views)
You do not have to use DSN, you can wire in a connection string constant.
Message 5 of 11
(8,076 Views)
Perhaps that's even more convenient than a UDL.  I like it, thanks.
Jim
Message 6 of 11
(8,073 Views)
Thanks for that tip.  I'd rather use a connection string instead of a DSN.
Ron Deavers, CLD
Message 7 of 11
(8,042 Views)
kindly let me know where i can download labsql. The original link from travis is not working
Message 8 of 11
(4,366 Views)
If original developer for this doesn't offer a link to a 22 year old tool, i doubt it would work anymore.
Message 9 of 11
(4,347 Views)
Fine is there any alternative to labsql ..like some other 3rd party tool
Message 10 of 11
(4,334 Views)
