database fetching
Does anyone have a good example of a "database fetching example" as the one in the examples does not work. Gives no errors but does not display the data.
I want to search the database in the first coloumb (serial number) and then display its corrasponding data in a single row if it exsists. I am using UDL with a MDB file. Just trying to get a proof of concept working at this state.
So if I have
Serial     Name    Company
33333     Bob       Spub
22222     Jim        Lemons
And I search for 33333 it will display Bob and Spub.
Thanks for any help
Regards
Peter
(3,228 Views)
do you have the  I database connectivity toolkit? ..Just drop a query like "Select * from [Tablename] where Serial is 33333"
(3,216 Views)
I figured it out, but have another problem now.
If I use "numbers" in my columns in my mdb file, when I try to search its does not find the entry until I add a char before the number.
So....
Fetch 222 returns only 222
Fetch a222 returns data correctly
thanks
(3,205 Views)
Don't understand how you can say you have it figured out and then say you have a problem with the query. The correct syntax is "Select * from [Tablename] where Serial = 33333". This will return all rows with a numeric serial.
Please explain your 'fetch' command. I hope you really mean 'SELECT'.
(3,184 Views)
Oohh, for shure it means "Select * from [Tablename] where Serial = 33333" ant not "... is 33333"!  My fault!Smiley Indifferent
(3,172 Views)
Well lifes a long list of problems that get solved and then new ones appear.
fetching=select it seems. Sorry for the confusion. Smiley Tongue
Seems I must study more information around the use of local and remote database techniques.
Thanks for your help anyway...
(3,157 Views)
