datalog with time stamp in txt
I'm new to this. I used to have a few lessons in Labview in school once, and now I have to make a labview program during my internship. On my previous internship I also had to log data, but that wasn't with labview, but with software from the company. When logging data it would automatically write the date + time (hh:mm:ss) and then the values I was logging.
I have an example included with this post.
I wondered if there's a function that's very similar like this one. Cause this is what I really want. I'd rather have the logged data in a txt file so I can easily use the data in an excell sheet or others.
I found 3 kinds of datalogging in labview.
- Write file
- Write labview measurement file
- Write to spreadsheet file
I tried all three, or it's something I did wrong, but I didn't have the results I had in mind.
Do you have a suggestion? I would like to hear it.
(2,893 Views)
Try Export Waveforms to Spreadsheet File.VI.
(2,872 Views)
Hi HmanH,
Is your problem solved? Just to know if we can close the support request?
Thanks for the update.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(2,823 Views)
