datalogging was not happening during Noon 12'o clock and midnight 12 ( 12 hour format )
hello all,
1 issue was there in my client place. the issue was data-logging not happening at a particular time of 12'o clock and midnight 12'o clock ( system time --.>  12 hours format ). Only Exe was running, so I can't able to view the code .everytime they have to restart the system and after that only datalogging was happening .  Is there any change I have to do in System time format and properties. ??? your suggestions  ? pls
(3,157 Views)
Hi bhuvanesh,
Debug this "EXE" before starting your (important) measurements. There's no other way!
(Sidenote: things become very easy once you start to use the 24h format… :D)
(3,147 Views)
any instinct or suspect from your point of view ?
(3,124 Views)
Hi bhuvanesh,
Sure: You made something wrong when you compare timestamps.
That's why I suggested to debug your EXE (or even better test the VIs in-depth before creating an EXE)!
(3,120 Views)
