datasocket buffering
I have application1 and application2. Application1 is suppose to send data to application2 through dstp. Application1 acquires data from a NI-DAQ device at 20Hz (20samples/sec). The data is wired to the DataSocket Write. In application2, Data from DataSocket Read is logged into a txt file. It is found that some samples are missing. For example, in one second, the txt file in application2 is supposed to reflect 20 samples/sec, but it only show, say 17 or 18 samples/sec.
I know that this can be done through client or sever buffering, but i do not know exactly how to do it. Pls advise.
(2,867 Views)
Hi DAQmx
You have an example of sending images with Data Socket. You can find that in NI Example Finder, names: DS SendImage and DSReceiveImage.
Anyway, if it is very important not to loose any data, DataSocket may not be the best solution. TCP would work better.
Hope it helps,
Aitortxo.
(2,862 Views)
