datasocket error, could not open, server or user limit reached.
HI All,
Having a problem with Datasocket.  I am using it to write from the server - non buffered - as a means to get access to some string parsing if required in an exe.  The problem i get is the server runs fine for hours, however every now and then I recieve an error which states system or user limit exceeded when trying to open the datasocket url (In the server).  Here is my setup.
[SERVER]
Launch Datasocket server if "localhost"
Minimise Datasocket Server
Open DS Connections A + B
do my testing - broadcasting data over A + B (write DS Only)
Close DS Connectns A + B
[CLIENT]  // not always used, only used for Debug
Open DS Connection (A or B or Both)
Read DS Info as long as you want
Close DS Connection on Exit
The server is in a loop for oven tests which is repeated every 15 mins or so over a 12 hour period.  Hence i am tending to think there is either a DS buffering type error, or more likely a referencing/handle type error similar to not closing down VISA reference's  However i cant see where i leave any references open....  All DS operations are in one vi on the server as above, which is where the error is originating from.  I do not close the data socket server  as i see it is a vi so should just remain in memory and calling it again should not open another one (Or so i assume, unless it is reentrant or something wierd)
Any Ideas?
Thanks in advance
Craig
LabVIEW 2012
(3,300 Views)
Hi Craig,
Are you able to give us an error code?  Or even better would be a screenshot of the error message and this should help us to narrow down the issue a bit easier.
Also if you have a bit of example code as to how you are using this that would be useful.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,279 Views)
Hi James,
Has not happened for a while, but if  / when it does i will try to get a screenshot alongwith some sample code.
Craig
LabVIEW 2012
(3,258 Views)
