datasocket question
My main program always has "error 1184: DataSocket Open, path not found, FTP login incorrect, no FTP write permission."
I found the error is from one of the subvi (enclosed, in LV2014): in cases " create and configure objects" and "start monitoring".
I have no clue, can anyone help?
Thanks so much
(2,873 Views)
is this question clear? Thanks
(2,839 Views)
Hi idjuven1,
Where does those subVIs come from? Are they part of a driver/library? Or are they custom subVIs? In this case, it will be helpful if you share that VIs as well.
Can you also share an screenshot of the error?
Gaheel17
(2,831 Views)
Thanks so much.. Here are the picture errors.. Can you run the vi?
(2,818 Views)
Your welcome!
I am not been able to run the VI. That is why I asked you if those subVIs require a driver or were made by you.
Gaheel17
(2,808 Views)
