datasocket read characters
I'm using the datasocket read function and I noticed that if my php page contains less than 4 characters the function returns an error.
For  example <?php echo 'abc' ?> returns an error but <?php echo 'abcd' ?> doesn't.
Is that normal?
Is there a way to have the page content whatever is written in?
Thank you in advance for your support.
Bim
Message 1 of 10
(4,959 Views)
Message 2 of 10
(4,945 Views)
Hello.
Could you give us a screenshot of the error please?
Thanks in advance.
Regards.
Romain D.
National Instruments France
Message 3 of 10
(4,938 Views)
You'll find attached the diagram I'm using.
Message 4 of 10
(4,932 Views)
Hello.
Could you give us all your code please?
I will try to reproduce your issue about it.
Thanks.
Regards.
Romain D.
Message 5 of 10
(4,906 Views)
The datasocket read function itself is sufficient to reproduce the issue.
You just have to access a web page that includes the php code I mentioned in the 1 comment.
Message 6 of 10
(4,903 Views)
I reproduced your issue.
I have never heard about this problem like my colleagues.
I will submit it to the R&D, and I will tell you more when it's possible.
Best Regards.
Romain D.
Message 7 of 10
(4,891 Views)
Hello.
Could you tell us which version of LabVIEW do you use?
How are you writing to the HTML? Are you hosting a web server that you are writing to?
R&D would be very interested in seeing a screenshot of the VI  that is writing the data, as well as reading it.
Thanks.
Regards.
Romain D.
Message 8 of 10
(4,873 Views)
I'm using LabVIEW 8.5 PDS .
I've run the test on an html page and I don't reproduce the issue, both characters are returned.
I don't host the server, and I also don't wirte anything on it in that case, I just get back what it returns.
Message 9 of 10
(4,869 Views)
Hi Bim.
Thanks for your reply.
I think this KB which helps you to solve your problem. You just have to put [HTML] at the end of the URL.
For the moment there is not another way to solve this issue. I have already seen this KB but I want to know if the issue is fixed.
I test this way this morning and DataSocket Read returns the good characters. Let me know if it's ok for you.
Thanks.
Regards.
Romain D.
Message 10 of 10
(4,833 Views)
