date comparison
The thrid message in this thread which was posted by you is marked as the solution.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 20
(8,454 Views)
My apologies Mark
I meant no disrespect. I've fixed it now.
Thanks and best regards
Ray
Message 12 of 20
(8,451 Views)
Not a problem. I'm glad it worked out for you. BTW, I'm not sure your algorithm for the Julian Date is correct. It looks a bit different than what is described here.
Mark Yedinak
LabVIEW Champion
Message 13 of 20
(8,444 Views)
Mark
The Julian date vi is one I got off the NI Zone...there were actually two of them.,...one does the reversal.
Ray
Message 14 of 20
(8,441 Views)
Message 15 of 20
(8,438 Views)
The numbers look quite a bit different. Here is a revised, and a bit more readbale, version for comparison. BTW, your version is actually off by a day.
Mark Yedinak
LabVIEW Champion
Message 16 of 20
(8,430 Views)
Thanks Mark
I've coded it up and posted it here for anybody who might want it. How would we go about letting the NI Developer Zone know about this flaw?
Regards
Ray
Message 17 of 20
(8,422 Views)
Good Afternoon Mark,
I will fix this flaw for you in Developer Zone.  Thank you both for finding this problem for us!
-Cody C
Message 18 of 20
(8,397 Views)
-Cody C
I am trusting the examples of Julian Dates I found online. I would guess that it is a rounding issue in the algorithm that was posted originally. Either way, the formula node implementation is easier to read and matches the published algorithms I found. The pure LabVIEW implementation was a bit more convoluted.
Mark Yedinak
LabVIEW Champion
Message 19 of 20
(8,393 Views)
Well, thats what you get for looking at older code.  That does seam to be a bit Rube-Goldberg.  My Production test mainline defalts to 1 *.csv report per day with header.  So I need to add the header on the first run of the day.  Easy since the report is JJJJJReport.txt
Here's a snippet of the relevant parts
The Time Stamp is test start time- the format specifier %y%j gives me 11049 today
Message 20 of 20
(8,386 Views)
