date/time string to w
Can it possible to convert Date/time string to word formate.??
here in attachment I have attached the vi in which i want to convert date/time in word formate.
Or please suggest me any other possible way to have Current date and time in word formate.
thank you very much...
(3,418 Views)
Can you please explain what this "word format" means?
Coz your VI is converting String date time into numeric which is not possible with the double !
(3,404 Views)
Thank you very much for reply.
ohhh, I am sorry ...I want to convert that string date and time to numeric.
in attached vi i tried but i didnt get the result what i want menas time is not varing.
can you please suggest me how can i solve this problme.
thank you very much once again.
(3,400 Views)
Are you referring to the different time scales in word/excel vs LV?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,398 Views)
No I am not referring to the different time scale.
Actually, in my main programm i want to set this time and date formate so when user start reading then he can see that at what time he took the reading and all this reading are saved in .txt file after finishing the programming.
Thank you very much...
(3,394 Views)
So you  want to save the Date Time into a text file.
As in your example you are doing the Date/Time to String.
- It can display the current time
- It can be saved into a text file because its a string itself.
(3,369 Views)
