dbl doesnt show decimal on different PC
there is one issue, perhaps someone could help.
I have application which work just fine. It is used for temperature readings.
On one PC, where app is developed, app works just fine and shows temperature, as example 24.23 degree C.
On another PC same application, same indicator shows 24.00. Value is rounded.
Indicator is dbl.
In app there is also other dbl indicator, which shows some other parameter, and they working just fine.
This very strange...
If someone has idea, it would be very useful.
(1,185 Views)
Accepted by topic author milan87
Hi milan,
please check the system decimal separator setting.
Do both computers use the same, either point (English) or comma (like German), decimal separator char?
(When it is only that specific indicator you can also check its advanced formatting options…)
(1,183 Views)
Thanks for fast reply
(1,158 Views)
