dc motor speed control with a controlable power supply
I am looking for a way to control a "Thurlby Thander PL330P" controllable power supply in labview. My knowledge of labview is very little and im sure this probably isn't that difficult. I need to be able to vary the voltage going to the power supply so that i can control the speed of my DC motor.
I have connected up the power supply via a GPIB interface cable. (NI-488.2) and i am using LabView 8.5.
Dose anyone know how I would go about doing this? Or could supply any useful examples.
Thanks.
James.
(3,188 Views)
(3,183 Views)
thanks this helped with learning some of the basics, however it still dosnt answer my question.
(3,177 Views)
Did you bother viewing the videos on connecting hardware and acquiring data?
(3,172 Views)
Accepted by topic author zimbo1990
Get the LabVIEW driver by using "Help > Find Instrument Drivers... " or here:  http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E97F2659CE034080020E748...
I didn't load them but usually there are some simple VIs to send commands to your hardware.  ALWAYS look for instrument drivers for new hardware.  It saves you a lot of tedious work if they're available.  Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,171 Views)
ya i have done that part already, it was writing the program for controlling the power supply  that i was looking for. but it is ok now i have managed to write one that work some what sufficently.
(3,159 Views)
thanks NIquist, that will be usefull later on. Smiley Happy
(3,158 Views)
