debug exe
How do I debug an executable?  I have a program that works fine if I run the VI directly, but when I run the exe, it doesn't behave properly.
Yik
Kudos and Accepted as Solution are welcome!
(6,607 Views)
Yik, it's pretty simple - the following will walk you through the process:
Remotely Debugging Executables in LabVIEW
Essentially make sure debugging is enabled when you build the exe, then connect to it using Operate > Debug Application or Shared Library from the LV menu.
Cheers,
Misha
(6,598 Views)
