debugging an Error 66
I have a vi returning an Error 66.  I can access the the same site with IE reliably and can use the same vi to access other sites without trouble.  How do I track down the problem?
Earl
(4,646 Views)
Hai,
Have you looked at this error code?
Please post ur code more specific. Give bit more informations.
Mathan
(4,644 Views)
The error message is "Error 66 occurred at TCP Read in TCP Buffered Read.vi:2->URL Get HTTP Document.vi:1->show HAN event.vi"
(4,621 Views)
Checking the log on the server, the http request is being processed, but the vi is throwing the Error 66.   Although the problem is mostly repeatable, the vi did actually receive the reply packet once.
(4,605 Views)
Not sure if it helps but I'll share anyway.
When I wrote my version of the Leader Board I ran into an issue where the server stopped responding to my code after a short period of time. I came away from that experience convinced the server thought I was a "Denial of Service" attack and just stopped talking to me. So....
The "fix" maybe on the server side and not on the LV side.
Ben
(4,595 Views)
Yeah.  I thought of that as well.  In fact, I ran some checks with the server developer.  The server log shows that it receives the http request and responds without throwing any errors.  I can run the  same request on IE successfully and see the same "normal" log entries.
earl
(4,585 Views)
