debugging tip
Too late to edit but I wanted to add that with DETT you can look for the mysteriously enqueued element and there is a column that says which VI it happened in. You can double click that row and it will open the block diagram and highlight where the enqueue (or dequeue) happened.
LabVIEW 2012
Message 11 of 13
(940 Views)
If you happen to be using the one platfrom where the DETT is available.
Lynn
Message 12 of 13
(936 Views)
The state is not entered consistantly.  That's why i am trying to understand how did it get in there.  Looking at the code, I don't see why it would go into the state at all.  I am sure that I am missing something, but I can't seem to find it now.  I will try to methods proposed  Thanks!
Kudos and Accepted as Solution are welcome!
Message 13 of 13
(920 Views)
