decimal point format: period/comma
Hi guys,
I used the 'Format Into String' function. Here I edited the format string into '%.3f;', which means I tell labview to use a decimal point. But when I probe my formated string I see a 'comma'. I use labview 2010.
What is wrong here?
Message 1 of 13
(49,947 Views)
what country is your computer set to? in europe this would make sense
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 13
(49,943 Views)
What? Belgium. Why it make sense in Europe?
Message 3 of 13
(49,934 Views)
A few things:
  • Your computer has a language setting that defines the comma as decimal point.
  • Your LabVIEW installations is set to use localized decimal point, meaning the decision between comma and period depends on the language setting of the OS. (tools..options...front panel...general)
  • You can also overwrite this in code, e.g. using "%.;%.3f" as format string. This will give you a period.
  • For details, look for "localization codes" on the format specifier syntax help page (bottom of first table).
Message 4 of 13
(49,928 Views)
%.3f just tells LabVIEW to use 3 decimal places, it doesn't specify whether it is is decimal point or comma.
Look in the help file for format specifiers and then localization codes.
If you want to force it to be a decimal point use %.;  for a comman %,;
Message 5 of 13
(49,926 Views)
[quote]You can also overwrite this in code, e.g. using "%.;%.3f" as format string. This will give you a period.[/quote] Hello, can someone please give me an an code example how to use it. I stuck atm a bit. Tank you very much Thomas
Message 6 of 13
(49,752 Views)
Hi Thomas,
In the Attachment you can find a small example. In the example there are two numbers and one is forced into a period and the other into a comma.
When you wire multiple inputs to the function, you also need to configure all of the inputs in the format string.
If you have further questions, don't hesitate to ask them.
Cheers,
Nico Lammens
NIBE AE
Message 7 of 13
(49,669 Views)
I've got a problem with the "Read From Space Delimited File" from this support link:
http://www.ni.com/example/25669/en/
The problem is that the values behind the decimal point are not copied into the final array, even though the indicator field "Spreadsheet string" on the front panel shows that the decimal values have been read correctly from the example text file. Can anyone explain why this is happening please?
Message 8 of 13
(40,707 Views)
Hi Ribbster,
what have you tried so far?
What are your regional settings as described in the messages above?
Message 9 of 13
(40,701 Views)
thanks for the quick reply!!
• I have unchecked the box as mentioned before
tools>options>use localized decimal point (I live in Germany)
having done that, I tried to directly insert a decimal point into my final array, which didn't work, I could still only use commas.
• when I change the string format to %,3f for example, the final array is filled with zeros
It is weird. I should say that I use parallels desktop on mac OS. Does the example work on your computer?
Message 10 of 13
(40,694 Views)
