decrementing conditions
I’m sure this is straight forward!
Im looking for something that will out-put a fixed numeric value of 0.3 when the process variable meets the following two conditions:
PV range between 3– 0
PV value was decrementing towards 3 from higher value first, and should not do this if the process variable initially started at 0 and is incrementing through 0- 3 and further..
Any ideas?
(2,206 Views)
worked out a soltution my self,l attached in case anyone els has a use for the code
(2,185 Views)
