default file extension
Under Open/Create/Replace File detailed help, it says that I can make the dialog box display a default file name or extension.  How would I go about this?  I want the dialog box to only show a specific file type.
Thanks.
(3,751 Views)
I forgot to mention, I'm running LabVIEW 2010.
(3,749 Views)
Accepted by topic author rickford66
Just use "File Dialog" and wire the output in to your "open/create/replace".
(3,735 Views)
Found it.  Thanks.
(3,731 Views)
