default value of string
Dear all,
I have developed a program in Labview. In my program, there are some "string controls". I need to enter the value when file is opened(for example: IP address,port no.).Do you know how to set the default value of "string control"? I don't want to enter those value evey time. Based on the value may not constant, i don't want to use "string constant"
Thank you.
Kim
(10,846 Views)
type value, right click on control and choose "make value default".
Another method is to write a value to a local of the control early in the vis execution, if you use a state machine an initialization state.
I prefer the second method since I use queued state machine designs for most of my UI vis.
paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(10,841 Views)
when you're in edit mode, you can set the default value by right clicking on the control and selecting " data operations".
If you wanna set it in run mode you've to read/write from file. I think that this should be easier for you.
Software developer
www.mcm-electronics.com
PORTUGAL
(10,837 Views)
Thank you.
I have solved my problems^^!
(10,834 Views)
