dektec dtu-215
I have a DekTec DTU-215 USB-2 VHF/UHF Modulator and am trying to communicate with it using LabView. I want to be able to set the outputs such as frequency, power level, and on/off using labview rather than the StreamXpress software the device comes with. It has the ability to use labview by using .wsdl files but i am not familiar with these. any help would be appreciated.
Thanks!
(4,128 Views)
How are you trying to communicate with this device? Are you using VISA or serial? Also, check this forum http://forums.ni.com/t5/LabVIEW/How-to-import-WSDL-file-into-LabView-8-6/td-p/1063387/page/3, where they conclude that you only access it with a web server. Is this similar to what you're trying to do?
Thank you
(4,111 Views)
I am trying to set simple parameters of the device. It is a USB device however it does not use a VISA handle. It supposedly can use .net but again i am not familiar with that. I was hoping maybe someone had used a device similar to this one.
(4,098 Views)
I've been looking for information regarding the WSDL files and LabVIEW. I found this link.
http://lavag.org/topic/8000-import-web-service-function-and-ws-on-java-lv-8-5/
He gives some steps to create a library that LabVIEW can call. He explains in one of the replies that he used the WSDL.exe that comes with visual studio.net (found in C:\Program Files\Microsoft SDKs\Windows\v6.0\Bin on my machine). Basically, he used the wsdl {parameters} {path}, I quote ''For example, if my wsdl is called sample.wsdl and it is in my c:/temp directory I would use the following command: wsdl /language:CS /out:C:/Temp C:/Temp/Sample.wsdl'' This will create a C# file (with .cs extension) from your wsdl, and then you can use Visual C# (from the command line or the IDE) to compile the file into a class library that LabVIEW can call.
Hope this helps!
(4,078 Views)
