delay after reset device?
IThe interface would only let me do 3 attachments and I need one more.  Here it is.
Message 11 of 13
(725 Views)
I had a use for this code as a subVI to reset a single device, so I cleaned up the code and made it a subVI. It's created as a LV2015 VI, so please down-convert it as necessary.
Note: This VI is provided as-is, so be sure to test it before you actually use it in your own code!
Message 12 of 13
(666 Views)
Updated to include module list. Basically, if you reset a chassis or something that has modules, you need to make sure all the modules are discovered, which happens some time after the reset passes.
Message 13 of 13
(616 Views)
