delay case structure
I am presenting one out of two different pictures ( in a case structrure)  on the control panel, based on some processing that is done sample by sample, by outputting a boolean variable(call it X).
What I would like to do is this:
If X is true -->  display PIC1
If X is false --> display PIC2, and maintain it for, say, half a second, no matter what is the actual value of X in this time range.
As of now, I managed to do basically this:
And this is not good enough for my VI, since there is an annoying flickering between images
Message 1 of 24
(5,326 Views)
I think that a Wait (ms) function would do it for you.
Look up in the timing Programming >> Timing palette the function Wait (ms) and wire the delay you want (in ms) to the left (as a constant or control). This should works.
Regards.
Mondoni
Message 2 of 24
(5,321 Views)
Thanks!
The problem is that the case structure ( and so the images) are into a while loop, but i don't want a delay of while loop ...
Message 3 of 24
(5,318 Views)
Nop.
Why don't you put your images inside the case structure?
Mondoni
Message 4 of 24
(5,312 Views)
I am not sure if I explained it correctly:
with the wait function, the vi will basically pauseexecuting for the specified amount of time, right?
I don't want this, I would like to have the function execute normally, and just the picture to "freeze" for a specified amount of time.
Would it be possible?
Thanks!
Message 5 of 24
(5,306 Views)
Check out this community example:
Display Image on Front Panel for Specified Amount of Time
Mondoni
Message 6 of 24
(5,297 Views)
Do you know how fast your loop is iterating?  If so, you can set a flag to FALSE and keep it false for so many iterations.  The flag can then just be ANDed with your boolean to determine which picture to show.  You will need two shift registers on your loop: one for the flag and another for the loop count.
Message 7 of 24
(5,286 Views)
Use the Tick ms to calculate how long it was since you showed image. If X = True or time (Tick(now) - tick(show image) < 500 ==> show image.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 24
(5,270 Views)
Hope this is what you are looking for,Delay is 2 sec once pic 2 is selected.
Let me know if something else is needed.
Thanks.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 9 of 24
(5,253 Views)
Did you notice that your VI uses 100% of a CPU core when the button is not pressed, slowing down everything else running on your computer? You only need to write a property when it changes, not over and over millions ot times per second. Right?
Message 10 of 24
(5,245 Views)
