delay
dear sir,
             I am reading data from DVL through serial port.dvl output is coming as below
AUTO_VEL_OFF
AUTO_VEL_ON
$#NQ.RES 0X0000 1 1 1 1 0.6 0.9 0.9 0.9 994.6 0.2 1.1 -439.3 0 0 0 0 0 0 0 0 1326.0 586.6 150.0 1 -495.6 1361.8 157.5 1 3.31 1.13 86.5 0.6 29.5  1545 74
:SA,+01.13,+03.31,086.5
:TS,00000000000000,35.0,+29.5,0000.0,1545.0,000
:WI,+00000,+00000,+00000,+00000,I
:BI,-00586,-01326,+00150,+00000,A
:BD,+00000000.00,+00000000.00,+00000000.00,0000.60,000.00
$#NQ.RES 0X0000 1 1 1 1 0.6 0.9 0.9 0.9 995.7 0.2 1.3 -442.3 0 0 0 0 0 0 0 0 1327.2 590.6 149.6 1 -501.7 1362.4 156.8 1 3.33 1.16 86.6 0.6 29.5  1545 68
:SA,+01.16,+03.33,086.6
:BI,-00590,-01327,+00149,+00000,A
My requirement is , I want to store the datas :SA,:TS,:WI,:BI,:BD in a single  xl file.what is my problem is the datas are stored in a file but every time it goes to the loop(serial read) there is delay between data capturing between the previous loop.ie first time it stores the 13 rows then it takes some delay and then it displays the next 13 values in a file.
pls suggest as soon as possible.
Thanks and regards
(2,862 Views)
(2,853 Views)
