delete array elements and resize matrix
Hello, I'm new to Labview so I am struggling with some ideas. I have the following matrix
A=[1   2   3    4
      5   6   7    8
      9 10 11 12
     13 14 15 16]
I want to obtain only the following resized matrix with the elements 6, 7 10 and 11, i.e.
B=[ 6    7
      10 11]
I appreciate your help
(4,221 Views)
Accepted by topic author Fco1235
On the Array => Matrix pallette, there is a function to get a subMatrix.
aputman
(4,210 Views)
If a 2D array, use the Array Subset.
(4,200 Views)
aputman is right. That function will get you the subset you need if you are working on a matrix. I would also say that you have to remember that columns and rows are 0 indexed.
Kind Regards,
National Instruments UK & Ireland
(4,159 Views)
