delete bits from binary file
Is there a way to remove few bits from start of binary file. All file functions are byte based, not bit based. My files are large (GB size) so I would prefer not to read/write files as characters as this takes a long time.
(4,834 Views)
I don't know what you mean by removing a few bits from the beginning of a file.
Files only store data in the units of bytes.  It can't read or write individual bits.
(4,810 Views)
What do you really want to do?  Suppose I have a file that is four bytes (32 bits) in length, and you want to remove 3 bits.  What happens?  Do all of the bits "slide down" by three?  Or is only the first byte affected?
If your file really is a bit-stream and you want to remove "a few" bits, you are pretty much going to have to read and rewrite every single byte.  However, if you read the file as a U64, or 8 bytes at a time, you can "slide down" your bits on the U64, potentially cutting down the number of separate I/O calls by a factor of 8.  You'll, of course, need to fill in the "missing bits" from the next-higher chunk, and will also need to worry about handling the final few "odd" bytes in the file ...
Glad I don't have to do this -- sounds messy.
Bob Schor
(4,808 Views)
It is.  I once had to interface with a UUT that used a 12-bit PCM stream.  Why 12-bit?  Saves bandwidth over 16-bit.  Enough to really matter in real situations?  No.  Complicated as $*^&? YES!  Worth doing?  Not in my opinion.
(4,793 Views)
