08-21-2009 11:59 AM
FYI:
I did NOT add that token to my 2009 ini.
FP objects WILL delete from the BD.
Ben
08-21-2009 12:04 PM - edited 08-21-2009 12:11 PM
Hi Darren,
here's my ini-file. I added the last line to enable deleting/copying after starting this thread...
Before that I only added "RegisterExtensions=False" as LV8.6 is still my "production" environment.
Yes, it was a fresh&clean install of LV2009 with no changes to the INI other than written above. And no, deleting/copying didn't work after install...
08-21-2009 02:28 PM
08-21-2009 02:53 PM
Hi Darren,
I just checked that: after "deleting" my INI (well: renaming) LabView allowed to delete controls from block diagram by default...
Now rerenamed my INI to get my previous settings back as deleting also works with setting the appropriate key. Don't know what happened while installation (or shortly after), as this "bug"/"bad behaviour" annoyed me from the beginning...
One more test and even better: now deleting also works without that INI key!
Well, that saved my day - going home now (it's 10PM here...).
08-21-2009 03:06 PM
I thought I had a similar experience earlier this week when I thought another config option was deleted (it wasn't, Thanks Darren).
Those of with the longer wires spools behind us can be easily disturbed if something we use get moved or deleted.
Ben
04-08-2010 02:16 PM
