delete duplicate in a array
hyul,
Describe the functionality again please.
If a number in the first row repeats in the any other rows, do you  need to remove the ENTIRE ROW or THAT PARTICULAR REPEATING ELEMENT ALONE??
Message 11 of 23
(7,654 Views)
i want to delete only the number not the entire row!
In fact i search the first number and i delete all the other.
here there is a small example witch explain what i want
Message 12 of 23
(7,648 Views)
In the VI i attached, Since, i am deleting elelments in the array, the each rows size will not be same. So, each row will be appended by some zeros. Is that OK?
Message 13 of 23
(7,641 Views)
i'm sorry but i cam't run it because i use labview 8.5, can you change the version of the VI?
Message 14 of 23
(7,639 Views)
Accepted by topic author hyul
Sorry, I forgot.
Here it is..
Message 15 of 23
(7,637 Views)
this is perfect, it's works
now i can continue my program
thanks a lot
Message 16 of 23
(7,636 Views)
good one my frien!
Message 17 of 23
(7,106 Views)
HOW DO YOU DO THAT WITH A 2D STRING ARRAY?
tHANKS
Message 18 of 23
(5,220 Views)
Prefer Using My solution & give me if any bugs
Message 19 of 23
(4,922 Views)
(First of all, this is not a solution because the input is not a 2D array as discussed.)
Your solution also scales very poorly for large input arrays (O(n²) because for each iteration, you start searching from the beginning, i.e. the first element gets touched over and over (N times!). In LabVIEW 2019, I would probably go with a "set" based solution if performance is a concern. Here's how that could look like (But LabVIEW 2019 already includes that array functionality as a vim :)). For the 2D case, you would just index out the key element and check the set.
Other solutions are also possible if output order is not important, e.g. if the input array is or can be sorted.
Message 20 of 23
(4,896 Views)
