delete empty strings from array
Yet another solution if you don't want to use OpenG:
Message 11 of 20
(7,943 Views)
thanks dan_u and _lan_ for your help any your solutions Smiley Happy
Message 12 of 20
(7,939 Views)
Nice solutions, but is there any similar, simple methods for a 2D array?:)
Greetings
Kristoffer
Message 13 of 20
(7,872 Views)
Sjefsgjogleren,
I would suggest you try to adapt that piece of code yourself. A second while loop would assist with the second dimension. However, it likely would need a few more small adjustments. Feel free to post your progress here and people will be more likely to assist.
Ben D.
Message 14 of 20
(7,838 Views)
Message 15 of 20
(7,831 Views)
This vi delete the empty rows from array 2D
Message 16 of 20
(6,182 Views)
This thread is 6 years old and solved. No need to attach an extremely inefficient solution that is also wrong. (For example it would output incorrect result if some rows contain empty and non-empty strings).
  • Why would you operate on columns (you transpose at the beginning and end) if the task is about rows?
  • Why would you need to measure the array size with every iteration of the outer loop? Wouldn't once be enough? The size does not change between iterations here (well, the compiler will probably optimizes this, but still ...)
  • "delete from array" typically does not belong inside a tight loop.
  • The inner loop iterates way too many times (# of empty strings << # of array elements).
Message 17 of 20
(6,173 Views)
I've used your suggestion but...each time the vi run the Array is not erased and it's populated keeping previous results.
First run
Second run
Where is the mistake?
Thanks in advance
I add my vi.
Message 18 of 20
(4,776 Views)
Sorry,
I;ve solved the case.
Thanks to your multiple examples.
Message 19 of 20
(4,769 Views)
What suggestion? My suggestion is to use the "Quote" button from the toolbar to indicate what's the post you are referring.
I cannot open your vi, but I guess you are not initializing a shift register. An uninitialized sr retains its previous value, so running multiple times may end in concatenating the results.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 20 of 20
(4,768 Views)
