delete external files from lv with system exec.vi, is it possible??
i would like to know the command line to deletes files from my application, since i save one file, use this file to convert to another and later i want remove both...
i try delete "c:\...\file.*" but i didnt get it...
Any help?.
Regards, Fonsi.
(2,975 Views)
Hi Fonsi
Why do you want to use the system exec.vi if there is a vi for deleting files?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,973 Views)
Which is this vi??.
(2,960 Views)
Look in the File I/O>>Advanced pallete.
___________________
Try to take over the world!
(2,958 Views)
yes, i have solved it before.. thanks...
(2,954 Views)
