delete files
There is an error 1320 with the node of property and the files are not deleted. It is necessary also that I put one AND for the month because at this moment I only take account the days of the month.
Message 11 of 23
(2,188 Views)
There is nothing obviously wrong. Could you post one or two of your files which you want to delete?
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 23
(2,186 Views)
Here are some files.
Message 13 of 23
(2,182 Views)
I don't have any problems when running your vi. Check all paths and file-extensions. Maybe there is something wrong. Also access rights could caus problem (but I think there must be another behaviour then).
Using LV8.0
Message 14 of 23
(2,181 Views)
if it can indicate you better my problem when there is the error i have this "In Edition mode, LabVIEW cannot return a property for a component of the order which was not created yet."
i find strange that you haven't problem, i'm going to watch deeply my code. thx for your help.
Message 15 of 23
(2,174 Views)
i don't understand even with labview help how the file is delete by formating a chain. Why don't we use the task "delete a file". Are you sure that the files are quite deleted ?
Message 16 of 23
(2,173 Views)
Yes indeed - you're right. The files are not deleted actually, but your vi detects correctly which files should be deleted.
So what you can do is to place the delete file in the case where you generate the status string.
Using LV8.0
Message 17 of 23
(2,170 Views)
the tasks about the advance functions of files must be all control by GPIB so i can't delete or even deplace the files. Do you know something to do against this problem of GPIB ?
Message 18 of 23
(2,166 Views)
Since your files are of *.txt, I changed the pattern string to "*.txt"
Run in my PC > OK!
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 19 of 23
(2,163 Views)
thx so am i it's ok but it doesn't resolve my GPIB problem.
Message 20 of 23
(2,160 Views)
