delete in a string
I need to send the following string to my serial port:   AT+BT!<del>!   where <del> is the backspace key
How would I send the 'backspace' as described ?
Morné
(3,271 Views)
Concatenate a string constant to the string.  Set the representation of the constant to Hex display.  Put the value 08 into the string constant.
Message Edited by Ravens Fan on 07-31-2007 10:47 AM
(3,268 Views)
Hi Morne & Raven,
you can also use a string constant set first to normal display, input AT+BT!!, then switch to hex display and insert 08 at the right position - no need for string concat Smiley Wink
AT+BT!<del>! = "4154 2B42 5421 0821"
(3,248 Views)
