delete index from array
Hi Everybody,
I would like to delete some index from array. for example, in figure, 0, 3,6 and 9 index number (array 2) are delete from array 1. How can I do it.
thank you
(4,377 Views)
Hi 1085,
there's a DeleteFromArray function - just use it!
(Hint: start deleting with the highest index.)
It's a nice exercise to learn usage of FOR loops, autoindexing and shift registers.
You should be able to solve this after taking the GettingStarted section in the header of the LabVIEW board!
(4,373 Views)
Thank you for reply. How is deleting started  with the highest index. Can you send me example.
(4,359 Views)
Hi 1085,
you have the indices to be deleted in an array, sorted from lowest to highest: just use Reverse1DArray to have the indices starting from highest…
(4,345 Views)
Yes there is also the OpenG option which has a delete elements from array, which allows you to specify an array of indexes to delete.  It will sort them and remove duplicates so that the delete goes from highest to lowest.
(4,299 Views)
