delete multiple worksheets in excel
I am having some major trouble here i am trying to delete multiple worksheets from a workbook using report generation toolkit.  I can succesfully delete one sheet with no problem but when it comes to two it doesnt work i was hoping the one vi i have create to delete could be used multiple times to delete however many i want need.  Please does any one have a solution for me I have attached a test setup if anyone wants to play with it
(3,851 Views)
Brandon,
I can't look at your code because I'm using LV 8.2, but I think I know what is happening.  Make sure that after you delete the first worksheet, you use the Excel Get Worksheet.vi to make the next worksheet that you want to delete the current worksheet.
(3,846 Views)
(3,835 Views)
