delete picture compression in excel workbook programmatically
Hi all
i use report generation toolkit to create reports in ecxel, occasionally when i open report saved in another computer i get pictures pixelized or instead of presenting picture i get an icon . i found out that these phenomena is connected to a property defined in
Excel options->advanced->image size and quality -> do not compress image in file (see attachment)excel option.png
Is there a property or invoke node so i can set my excel workbook to uncompress files and if this property is under workbook or application?
(3,089 Views)
Hi Idan,
I browsed the LabVIEW Help and the Report Generation Toolkit Help, focusing on the following VIs
but I didn't find a way to disable image compression programmatically.
Alessia
(2,991 Views)
