deleting an virtual channel from a task
Hello all!
I use Labview 8.5.1 and DAQmx 9.0.2.
I'd like to delete an virtual channel from the task by program without deleting the whole task via "clear task" vi.
Do you have a solution, exemple in 8.5.1 Labview version to do that.
Thank you , Daniel.
(2,425 Views)
Hello Daniel,
I am not sure I have well understood your question.
You created a channel regrouping several physical channel.
And you would like to remove one physical channel? Or if I rephrase, you would like to select one channel active rather than antother. Is it your questions?
If not, could you please provide us a VI or a screenshot showing the initial situatition you are starting from? And a descritpion of what you would like to do with that.
Thank you.
Best Regards,
PS: for your information, there is a french section on this forum if you prefer.
http://forums.ni.com/t5/Discussions-de-produit-de-NI/bd-p/4170
Jean-Philippe C.
National Instruments France
(2,316 Views)
