deleting array element
    I am getting an array of 100 elements and i need to delete the the element if it contains 255.And most importantly the next element should be placed in its place.So if i get 30 255s then my output array should get reduced to 70.I tried search 1d array but it is returning only the index of first element containing 255.Please help!!!
Message 1 of 18
(5,392 Views)
Hi muks,
use a for loop and build a new array.
Mike
Message Edited by MikeS81 on 06-18-2008 01:43 PM
Message 2 of 18
(5,388 Views)
i need to handle 1500000 data. Some way to optimize it?
Message 3 of 18
(5,384 Views)
Hi muks,
ok, but to delete from an array in a loop is not the best alternative. How many entries do you want to remove?
Mike
Message Edited by MikeS81 on 06-18-2008 01:51 PM
Message 4 of 18
(5,382 Views)
I need to remove all the entries having 255 as its value no matter how many times it occurs.
Message 5 of 18
(5,375 Views)
Hi muks,
is 255 the highest value in your array? Do you need your array sorted?
Mike
Message 6 of 18
(5,372 Views)
Hi muks,
see the attached example to see the difference between delete from array and the other method.
Mike
Message Edited by MikeS81 on 06-18-2008 02:07 PM
Message 7 of 18
(5,368 Views)
   First of all thanx a lot for your effort.May be i didnt convey what i want properly.The value in my array is going to change randomly.I want to remove the index containing the 255 value alone.I have tried doing that.Please have a look.
Message 8 of 18
(5,361 Views)
Hi muks,
i think i understand what you mean, but i have to create a test array to work with. Attached you can see another way to delete the 255 without using a loop.
Mike
Message 9 of 18
(5,355 Views)
Thanx a ton mike.Also can you tell me if i want to remove values from 255 to 200 how i can go abt that.Also do u mean to say we cannot do the same thing directly using numeric functions.I would have got stuck trying this without u suggesting the string functions.
Thanx a lot mike
Message 10 of 18
(5,345 Views)
