deleting entries from data log
     Been looking into moving projects over to LV 8.2. I've identified what appears to me to be a bug:
I save a couple of entries to a data log file. When I retrieve the data and select an entry fo deleting, the final entry gets deleted and not the slected one.
I've tested this on a very simple vi with just a text box with 0,1,2,3....6 incrementing the number for each entry logged, I try delete then the entry with "3" in the text box and the entry with 6 is missing after I go back in to retrieve.
anyone else seeing this?
Message 1 of 16
(3,859 Views)
Hi ds_1,
can you show us your code, or tell us which function you use?
Mike
Message 2 of 16
(3,848 Views)
If this looks like a bug to you could you please either post the code or the name of the vi under Example Finder,
Message 3 of 16
(3,836 Views)
erm not sure how to post code... but this happens with all vi.
if I use "operate->log at completeion" and have a log file binding created,
I run a number of times (any vi with its own log file)
When I retrieve all log files are sequentially numbered and time stamped as expected,
I I try delete any entries, say the first one (earliest timestap) , second one etc, it is always the lastest timestamed (last entry ) deleted.
I will try check this also later today on another system
Message 4 of 16
(3,829 Views)
This Issue has been verified on a second system.
Please let me know how what other info you require to investigate this.
Message 5 of 16
(3,805 Views)
Hi
    I've attached some zipped screen shots of what I'm seeing, as well as code (and the log file that was binded to), although code just contains a numeric display for purpose of display.
   1: I created 7 log entries 0..6
Message 6 of 16
(3,786 Views)
Hi
Message 7 of 16
(3,786 Views)
Hi
   1: I created 7 log entries, to binded log file. Retrieved results and have displayed  first entry displayed, numeric = 0, note entries are 0..6
   2: showing last entry, entry showing numeric 6, also note time-stamp
   3: selected entry 3 to be deleted, clicked ok to removed entry.
   4: again retrieved logfile and have shown that entry 3 is still present, note: a single entry has been removed, entries now 0..5
   5: Last entry is now numeric 5, Numeric 6 has incorrectly been deleted.
Can you confirm this if this is a bug or where the problem lies.
Thanks.
Message Edited by ds_1 on 03-12-2008 06:09 AM
Message 8 of 16
(3,780 Views)
Hi.
     Any suggestions on this problem? This is becoming a real headache, at present I've had to move back to 7.1, after begining a project in 8.2, not to mention the time (and data) lost in discovering this issue.
 Is this a bug? Will it be fixed?
Message 9 of 16
(3,736 Views)
This is very unusual, I'm unable to reproduce it here - could you send you logfile itself and I can open it here and see if it's a write issue?
All the best,
Message 10 of 16
(3,685 Views)
