03-01-2010 12:03 PM
Hello Friends,
I have to design a simple demux in labview which transfers the input to a particular output driven by a line select.I am attaching an image of it. Please help.
03-01-2010 12:21 PM
03-01-2010 12:24 PM
Thanks for the reply
I am not able to wire multiple outputs through case structures. can u please elaborate how to do it.
03-01-2010 12:32 PM
03-01-2010 12:34 PM
Here is the picture of my VI.
U can see there is one output for the case structure inside while loop . I want to tranfer this output to the respective shift register depending upon the line select.
03-01-2010 12:37 PM - edited 03-01-2010 12:38 PM
Hi Srik,
wire all shift registers through the case structure and connect them so their wire run through all the cases.
Now you only need to replace the one wire that is used in the special case...
You need to rephrase your question:
Change from "How to de-mux one output signal" to "How to replace values in certain shift registers?"
03-01-2010 12:55 PM
Hello GerdW
I think i understand what you are saying.. Ill try to implement that and see what happens. ....Thanks a ton
